Investing a few extra seconds in good soldering technique can add years of lifetime to your newly-restored appliance, regardless of whether you use run-of-the-mill, or high-quality capacitors.
The manufacturer has (or has not) invested quality control during the manufacture of the component, but how the technician chooses to install and solder it in the PCB, will determine the actual lifetime, irrespective of what is claimed on the datasheet.
Here is a perfect example.
I was repairing a VCR (which had a sticker at the rear, showing the date of last repair as 3-2013), and in the power supply, there were 3 replaced 22uF 63V 105-degree capacitors, made by Samwha (Samsung Industrial) series RD. These are the EXACT capacitors which we find in many recent B&O products.
The 3 capacitors had all failed, with capacitance of between 6-10uF, and ESR more than 20 ohms. The cause of failure was quite obvious.
The lazy repair tech simply pulled the leads apart to fit in the 5mm PCB holes. Doing exactly that, irrevocably compromises the rubber seal position, and the electrolyte leaks out.
In the picture, you can see the gunk on the legs.
This piss-poor laziness, unfortunately, is standard procedure among most technicians.
If you want your capacitors to last, it is essential to bend the leads twice at 90 degrees (almost), as shown in the Panasonic EB at the left, so that the leads pass through the rubber seal without compromising its leak-proof ability.
Menahem
