do not be afraid to do the job and follow Soren's tutorial. It is not as difficult and the result will surprise you. Many of us tried this before with excellent result. From my point od view, this work needs patience ,but is very easy. See before and after status here:
/forum/general-discussion-and-questions/restoring-veneer-on-beovox-s45
Use reccomended stuff at first in wood work (alcohol, sending, linseed oil), then try to use tint or another products, when result will not be ideal.
