Hello,
picked up a pair of S75s that need some attention. Quick questions:
1) One speaker has the 2-DIN cable socket removed (it's modified with just a pair of cables). Does anyone know what part is the replacement / where I can buy it? Preferably with screws in the back so I can avoind soldering
2) Is there any way I can tell which wooden trim is used, so I can buy the correct Restor-A-Finish?
3) Stands: I might get a pair of S30 stands dirt cheap. I assume they are not a direct fit, but can I just take a small plate, drill the right holes and at least it will be OK visually?
