S75 restoration
Hello,
picked up a pair of S75s that need some attention. Quick questions:
1) One speaker has the 2-DIN cable socket removed (it's modified with just a pair of cables). Does anyone know what part is the replacement / where I can buy it? Preferably with screws in the back so I can avoind soldering
2) Is there any way I can tell which wooden trim is used, so I can buy the correct Restor-A-Finish?
3) Stands: I might get a pair of S30 stands dirt cheap. I assume they are not a direct fit, but can I just take a small plate, drill the right holes and at least it will be OK visually?
Beovox S30 stands would look wrong.
You need the Type 6012 stands, - unique to Beovox S75.
Wood sorts: See my post in this thread:
Thanks Martin. I know the stands are not correct. In which way would they look wrong? Will they do as placeholders until I find the proper one?
They would be very high, and I seem to remember the S75 feet are both wider and deeper to better balance the larger and heavier speakers.
These three combined, I wouldn't recommend.
Thanks. My plaque says T6313, I can assume these are Teak?
Anyone making cheap replicas? I need them up on something nice looking while I groom the setup over time.
Any idea about the speaker side 2din male connector?
Just tested the one speaker with original connector. BASS. CX100 sounds like a mobile phone in comparison.
The "T" in T6313 is for "Type".
The woodsort will be stamped on separately - if at all.
Look at the link I provided and compare.  Or give us a photo to look at.
like this: E is oak
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
Nothing of the sort on mine, but looks pretty rosewood to me. I will refurbish. What is your suggestion for repairing and refinishing the surface? I'm relcutant to sand them down. Is there any wonder product like Restor-A-Finish for us here in Scandinavia?
In case you have heard it all, where would you place the S75 in the Beovox "hierarchy" in terms of sound and desirability? I quite like them a lot with my BM5500, considerably more bass and much warmer sound than the CX100 they replaced. The latter were very crisp in the highs, but I think the S75 still retains ample trebles and a satisfying, unghostly mid. But compared to M-series and the bigger S'es?
I start cleaning with Isopropyl alcohol, depending on how dirty (layers of Pledge, wax or lacquered with something) at times I use acetone for the first cleaning, careful acetone may damage plastics and loosen glues.
Then sand the wood with 200 grain sand paper or
Retired
Rock and Roll music
Collecting Vinyl
Thanks, Søren.
