Hi Guys,
So long story short I picked up some S45 Type 6427 speakers for around $75 (US) shipped and knew that they would have to be refoamed. Unfortunately USPS dropped them and the one had a magnet issue. I mistakenly thought that I could fix it. In the process I ruined the voice coil (simple ignorance, I admit that I am as far from a trained professional as there is) and ended up chucking that woofer (possibly mistake number 2?).
My question is now... how would you proceed. The one woofer works and I have everything set to refoam it. Do I see if I can order a new woofer for the other speaker from B&O, if it is even possible? I looked and saw that someone on Instructables had used an aftermarket woofer and seemed happy with it. As a B&O diehard I am not sure if I'll be happy though...
Here's the link for the instructables as well as the woofer they used. I am open to all thoughts and opinions at this point.
http://www.instructables.com/id/Bang-and-Olufsen-Beovox-Woofer-Replacement-easy/#step1
http://www.parts-express.com/pe/showdetl.cfm?partnumber=290-314
Thank you!
