Restoring the Beocenter 9500
After getting help from you guys to bring my Beocenter 9500 back from the dead I have started to restore it into a good working condition.
So far I have tried to clean it up a bit. There are some major issues:
1.CD door does not close easily. It jams half way and you need to press the load button twice to get it to close or open completely. After cleaning the rails and lubing the brass axis I get it to function properly when the lid is in service position. The problem is when the lid is back in normal position. The the door engages the clamper arm (as it should) but it is not very smooth. You can actually see the whole CD mech move while the CD grips the arm and pull it into the open position. There is quite a lot of old grease on the underside of the CD door where the pin of the clamper arm engages. Should there be grease here? The servicemanual does a poor job explaining how to get best operation from the doors.
2. The lower glass panel is broken in two (surprise). I really need to find another one but 9500 ones are scarce. Does the 9300 work cosmetically? I understand that you loose the timer button. Have anyone tried one on a 9500?
3. Glass panels are loose. What kind of thickness is ok to use on the doubled sided tape to re-attach them? I have found one superstrong from Jula here in Sweden (a hardware store). It seams to be 1mm thick.
/Mikael
I can only comment on Q3 - I took advice from the old forum and simply used super glue gel to fix the glass back in place.  I left the old tape in place, hence no messy cleaning required.  This has worked well for two BC9500s (and a BL5000 screen!)
I'll be interested in responses to Q1 as my mother in law's BC9500 has the same problem and I have tried extensive cleaning with no success.  I think the cord may need replacing as it tends to 'stick' on the rotating metal spindle whilst opening, and looks as if it should slide sideways to make room for more cord.
Re Q2 - perhaps a BC9000 panel will fit?  There are a few of those around cheap as the CD spindle breaks (unrepairably) rendering them less useful.  This of course does have the 'Timer' button.
1. replace the door belts, done in a minute, cost just a few bucks and are readily available from B&O. can't tell you anything about the grease though
2. use the glue that is meant for car windshields to fix the old one or ask beoworld member Leslie, think he's got some glass panels left
3. either reattach them the original way, double sided foam tape: http://www.ebay.co.uk/itm/Black-Super-Strong-Double-Sided-Foam-Tape-6mm-X-10m-/400243210944 that should last 10-15 years. If you want a permanent fix, above mentioned glue will do the job, the one for the windshields (not super glue, remember the ugly white residue it leaves?)
Yes, replacing the belts is probably a cheap way to get better traction in order to move the doors. Hopefully there are some in stock at the local service center.
I have asked Leslie if he has a panel and are waiting for him to come back, but in case he doesn't have one then it is good to know my options.
Finally I have some pictures especially for Soeren (how do you make a danish oe on a mac keyboard) in Mexico:
The broken glass panel (sigh)...
The top stripped on all its panels. You can probably notice the long scratch on the CD door.
Some parts left to dry after cleaned with soapy water (they were really dirty).
/Mikael
Mikael wrote:
The the door engages the clamperarm (as it should) but it is not very smooth. You can actually see the whole CD mech move while the CD grips the arm and pull it into the open position. There is quite a lot of old grease on the underside of the CD door where the pin of the clamper arm engages. Should there be grease here?
Originally there was some grease, but it is now hard and sticky. The best thing to do about it is clean it away completely (do the same for the rails the lids move on) and relubricate with very little silicone grease. Apply with a cotton bud or something, never spray silicone directly on the target as it will get everywhere, even the places that should have friction.
Service manuals aren't usually too helpful with old age problems. They were written when the units were brand new! 🙂
We had email contact but I was not aware that you needed one from me, sorry! Will check tomorrow!
Leslie: It is probably me that wrote a confusing reply to your email. No problems!
Got one!
Leslie wrote:
Got one!
Great! What would the beo community do without you Leslie?
I also visited my local B&O repair center today and picked up two belts for the doors. They were only like 5 Euros or so a picece. So it is really a no brainer, just replace the old ones. A tube of silicon grease was also purchased, hopefully that will do the trick.
Stay tuned!
Hope that this will resolve your door problem but I'm afraid that it won't work. Most of the cases the rope or string becomes black and slippery and that's what causes this door problem. But still, you never know....
