Replacement glass avant crt
hi guys they gave me a broken avant 28 type 83/64 as my avant type 83/04 has a small mark on the glass I wanted to replace it. To disassemble the 83/64 glass on the lower part there are 2 round blocks, removed the frame, removed 4 screws and I have the glass in my hand. on my 83/04 I can't find how to remove the glass? does anyone know how to do it or should I take it all apart ?
I found for the type 83/04 it is necessary to disassemble the back and in the lower part of the screen from the inside there are 2 hex screws 4 mm inside the holes
