I have a Beovision 9 (BV9) and controlling an Apple TV via PUC. I bought a BeoRemote One BT to replace my Beolink 4.
Problem:
To control the Apple TV via Beolink 4 I use the navigation buttons (left, right, up, down) the center button of the navigation buttons and EXIT. So intuitive / easy to use.
At my BeoRemote One BT (in IR modus) the navigation buttons do not work any more for Apple TV. Instead I have to use search backward, search forward, P+, P-, Play and green dot. On one hand these buttons are confusing and from the layout it is not as convenient as the navigation buttons on the Beolink 4.
Questions:
1) Can somebody give me a hint, how to enable the navigation buttons at the BeoRemote One to steer Apple TV via PUC?
2) Any other solutions? Control Apple TV via Bluetooth (BT), possible? How?
3) Is there a solution to use BT and IR parallel on myButtons, without changing within the menu between Beo4Vision for BV9 and Bluetooth for Beosound Core?
