redline rl140 speakers restore project
hi guys
1 speaker sounds ok,the other sounds terrible with lack of base.
stripped both down,checked all cones for tears and there fine
then checked each speaker with a meter and there all fine.
so im thinking failure of crossovers
am i looking in the right direction?
Find 'Dillen' on this forum. If I remember correctly his has got a repair 'kit'
https://www.beoparts-shop.com/product/capacitor-kit-beovox-redline-rl140/
And check those woofer cone surrounds once more. They will need attention if not already re'foam'ed.
...or re-foamed incorrectly.
-sonavor
ive ordered 2 used crossovers that have been verified as working correctly
can replacement woofers be found/supplied?
