Anyone else uses the older floor stands for the Redline range (the brown ones)? I thought it was strange that the speakers always point downwards (looks ugly too) but then I got the manual and it shows an adjustment screw. But mine is missing. I'd like to get a replacement but I don't know which kind of screw will fit since the manual isn't at all specific.
Redline 60 speaker stand adjustment screw
I'm not with my RLs now, but wasn't it so that the threads for the screw are in the speaker itself and not the stand? If so, remove the support prop and the rectangular metal bracket under it from the speaker (only four screws) and take the bracket with you to a hardware store to try what fits.
It'll be a metric thread anyway... if you have a shop that sells screws, bolts and nuts by the kg, you could just as well get some of everything M4 / M5 / M6. One of them will fit, and it'll still cost pennies.
It seems to be easily removed. Thank you very much!
