I have BV7 (opt 1) and BC2 (opt 1) connected to MLGW (2.24b) and controlled by iPhone BeoLink . If I only BV7 turned on and I send the ALL STANDBY signal, stand parks to "stand-by" position. If I have both BC2 and BV7 turned on, then ALL STANDBY switches both units off, but the stand remains in the "active" position - does not park. If I use both sources, but send only TV STANDBY command, everything is fine.
Monitoring shows the same in all the cases: e.g.
2017-03-22 22:17:27 E: ALL STANDBY
Any ideas? bug or feature?
