Hi everyone, I have a Beomaster 4400 in pretty good condition but with some light scratches in the top cabinet. The plan is to carefully sand the cabinet and apply boiled linseed oil to bring it back to original condition.
What is the recommended approach to sanding the veneer? It seems that the metal strip is glued on and would be difficult to remove. Should I just tape off the metal strip with masking tape so that it won't be scratched when sanding the veneer?
Thanks!
