Hello there. I own a Beosound 5 / Beomaster 5 since a year.
I think that for a high-class, expensive product like this, some details should be improved; any of these are as following:
1 - Swithchin' on the device, and selecting "net music" the music starts suddenly with the pre-defined volume. I think it would be more elegant if the sound would start very low, increasing little by little, until reaching the pre-defined volume.
2 - When you select "net music" directly on the device, the music start playing, with the last song played in the previous time. In my opinion, it would be better to have the possibility to select the song/album to listen to, before the music stars playing. (now this is possible only if you command the device through an Ipad)
3 - when you need to select an album (or a song), you need to rotate the aluminium wheel, until the display shows what are you looking for. If you stored a lot of musical files in the Beomaster 5 (that's my case), you need to rotate the wheel more and more and more..... In my opinion it would be more comfortabe to add a command that makes the user select before the first letter of the album, then the album title.
The three above are just the first three possibilities I have in my mind now, but I have found some more....
In my opinion, B&O launched this product without refining some important details, and still now, years after its launch, nothing has been changed.
It's a pity, 'cause you can not realize these little lacks, until you have installed the device in your house.....
