Good evening to all,
I was so happy to get a BS9000 cheap today.
Well, joy lived short. After further investigations and reading on the forum I think I was too presumptuous thinking it would be easy to fix. The unit was sold as defective so all my fault…
Good news is Radio works and A.Aux can be selected. Sound control works too.
At first as soon as ou selected CD, the unit did go Standby.
The glass door looked like stuck on the right and wobbly on the left hinge.
I tried to force opening but it resisted to the point where the glass detached itself from the metallic support.
So I completely removed the glass. I could verify the left hinge has a very lot of play. But since then the load command seems to work (not consistently but as the unit is in bad shape, can't say if its related).
The CD clamper when moved manually can display CD1 and CD2 (have not tried other slots). I even manage to get a timerand "pause" displayed. The disc did move a little bit like pushed from below but it didn't spin and i didn't notice anything else.
I was trying to release the sledge as Beobuddy recommended in another thread and also following the Service Manual but here started my fears.
1- I can't see any "big wheel" under the carriage to be rotated by hand.
2- When I look into the groove over the CD slots I can see two pulleys on each extend but can't see any wire or cable around them. As the carriage seems to move quite freely I fear parts are missing.
So now I'm wondering if I didn't buy a dead body, donor of some parts which are now missing.
I've attached some pictures below.
Please any advice or help would be greatly appreciated.
The left wobbly hinge, please notice the oval axis hole
The carriage below with no big wheel.
And one of the pulleys with no wire around Login to view image.
Thanks for reading.
