Hi all,
I'm restoring a pair of Penta IIs. The component upgrades are going well - thanks Martin.
I'm now doing the foam surrounds. I ordered a set from GoodHiFi which arrived promptly with good customer service and communication. I have three questions for people who have done this job:
- Do the new surrounds fit to the inside edge of the metal frame or sit inside by 2-3mm?
- Do you glue both the cone and surround or just one?
- After applying glue to the existing cone exactly where the glue was previously, I'm finding the lip of the foam doesn't line up to the glue line. The glue sticks to the flexible part of the surround, not the lip where it is supposed to. e.g. the lip of the foam is too far towards the dust cover in the centre. Is it just this particular surround or do they all do this? (See right hand side of pic)
I've ordered another set from Audiofriends in the hope that the size is slightly different. I don't want to do this job with 90% accuracy. I'd like to get as close as possible to the original.
Any advice appreciated - thanks
Update: after typing this I found another thread which says it better than I could:
/forum/imported-unmapped/where-can-i-get-decent-foam-surrounds-for-pentas
The question still remains, is the Audiofriends foam a better fit than GoodHiFi?
To be clear, I'm not having a go at the company. They have been very efficient with the order.
Also, if anyone is interested, I've taken pics of all the steps if you want photos of any of the before and after shots.
Cheers
