Hi
Can a Beoremote One BT be paired with Beosound Essence MK2? I have tried without success.
And yes I know I can use it without bluetooth with an IR eye which I do at the moment.
Hi
I just tried it, and it works fine. Make sure your Essence MK2 is updated (new sw today).
With the latest software - of today - all ‘connected devices’ can be paired with a BROne/bt.
It can do both simultaneous. Try a reboot.
Just to clarify, does this include the A6?
Yes. I could pair my remote with an A6; but am still struggling on pairing with an EssenceJust to clarify, does this include the A6?
I was able to pair with my BS1 and A6 effortlessly. I see that it keeps multiple added products in its list of products. However, it only remains paired with the last product paired. It can't retain the pairing with multiple products.
You CAN however keep multiple remotes paired with a device. For example, keep a BeoRemote One and an Essence remote both paired to an A6.
After the software on the Essence was updated the paring of the Beoremote One worked fine!
This is great. Now I can see the TuneIn stations on the Beoremote One.
But this new setup also raise some questions?
