NL/ML Converter with Beosound 9000 and Besound/Beomaster5
Hoping somebody can help me? I powered down the above devices for sometime. Recently I powered everything up again, the NL/ML converter doesn't recognize  the the BS/BM5 nor the 9000 player as it did before.
Should I power down the converter, then plug each source in one at a time so the converter will recognize these sources? Should each source be on and playing before try to add each one?
Note all of the above worked perfectly before I powered everything down, with the converter connected to the Beovision Avant and attached speakers.
Anyone else had this issue?
Thanks..Joe
Hello!
I do not have an answer but I would just try to power up the product again one after the other starting with the converter
had the issue that converter did not provide TV-sound to ML network; a hard reset (unplugg) helped me out...
otherwise you would have to setuo the converter menu...
best regard Elmar
