NL keypad button ideas
Source buttons are a good idea.
As I said earlier. Try the dimmer up and down for volume it's quite helpful
I've used the up and down buttons before on Lutron keypads for step-ups and step-downs for volume. Repeating key presses until I reach the desired volume. I've been reluctant to program them, however, for continuous volume up and down though. I'm worried about loss of connection resulting in run-away volume increase. Did you program them for continuous presses for volume?
I use them only for finite button up. I'm afraid of continuous up volumes!!I've used the up and down buttons before on Lutron keypads for step-ups and step-downs for volume. Repeating key presses until I reach the desired volume. I've been reluctant to program them, however, for continuous volume up and down though. I'm worried about loss of connection resulting in run-away volume increase. Did you program them for continuous presses for volume?
I'm so glad you found this thread, Kiran! It thought you might find it really relevant to your project, and I welcome your ideas.
In reading the BeoSound 5 user guide, I found that the numeric favorites just plant a song as a seed for the MOTS. I wish that B&O would have given us the option to use the numeric favorites for other uses -- such as storing entire playlists. We have much more flexibility in what we can assign to both colored and numeric favorites in Spotify on the BeoSound 5. I'll be sad to see Spotify removed from the BeoSound 5.
I've found that some functions of the BeoSound 1 such as AirPlay would make no sense as a button. For example, to get AirPlay on a device, you must "push it" to the device from an Apple device. Once you change the source on the BeoSound 1 to something else such as Deezer or TuneIn, the AirPlay connection is lost and you must re-push it from the Apple device. I could also see the up and down buttons being useful for moving between tracks, stations, and playlists within sources.
Something else useful from creating macros in the BLGW is that we can then trigger those functions using Amazon Echo voice commands via IFTTT.
Experimenting with the keypad is a great way to explore some of the additional NL functions found in the BLGW. I'll be able to explore this further when my BeoLink Converter and BeoPlay M5 arrive in a couple of days.
