New support for BeoRemote One BT
Yesterday, we saw a a software update to audio bluetooth products that enables pairing and control with a BeoRemote One BT. However, there is no support for LIGHT/CONTROL functions! This is a disappointment.
UPDATE:
It seems that you need to first enable forwarding of LIGHT/CONTROL commands to the blgw in the audio product settings BEFORE pairing the remote in order for LIGHT and REMOTE to appear. However, pressing the commands listed under LIGHT or CONTROL has no effect. Can anyone confirm if this is the situation for them? Is is the same for a BeoRemote BT paired to control a BeoVision?
come again?  So we can now use a BROne with a BeoSound 1?
Yes. We can!
However, I can't get the LIGHT or CONTROL on the BeoRemote One to work. Could this have something to do with the new BeoLiving Intelligence not using legacy IR commands? Do we need to change the macros somehow?
Do I have to put it into beosound mode ?
Is there a manual for all of the functions and or models you can use it with?
πŸ₯³πŸ₯³πŸ₯³
πŸ₯³πŸ₯³πŸ₯³
I believe it works with all of the multiroom BT audio systems except for the Moment. I emailed Lyle and he responded that the Moment won't be updated to support a BT remote.
All you have to do is make sure your audio device is updated with the new software that rolled out this week. Then, you use the B&O app to make the product open for remote pairing and then open the BeoRemote for pairing. The BeoRemote will automatically list the audio product by name in its product list. You can add multiple audio devices to the list and they will remember their pairing. The BeoRemote One will list all of its audio sources under the MUSIC button. Here's the fun part: TuneIn will list all of your favorite music stations on the remote!
The current BS1, yes....not the old one!
However, you can use a BROne in ir-mode for that.
N.B. This is already rhe third thread about this new support of the BROne/bt πŸ€”
This thread relates to the home automation with BLGW.
Stop trolling, MM.
Thank you BJ
Yes I don’t need a hall monitor 😁
I can’t get it to work. I must be doing something wrong lol
Nothing shows up in the list
You need to select Remote Controls instead of Bluetooth in the App Configuration page. Then hit "Pair" :)
