Hi, my problems started with 1.5.3. I have send a case to Beointegration but no answe yet.
new firmeware BLGW
My problems started with 1.5.3, too. For me, the BLGW is not recognizing the video master. However, the video master (Beosystem 3) is still transmitting LIGHT and CONTROL commands.
hi, same here! Beosystem 3 (BV9)
I'm also finding that a BeoLab 3500 is no longer responding to macros that trigger the ALL STANDBY command. However, the 3500 is still responding to other macros and will respond to an ALL STANDBY button press used by the Beo4 on other ML products.
I have got a new corrected software from Beointegration. Now all makros and my beolab 3500 and everything works perfect. So if you have problems with the new 1.5.3 just ask for the corrected software and manually download it to the BLGW.
96 Normal 0 21 false false false DE X-NONE X-NONE
New firmware on hue side!
The hue connection to the blgw failed every 20 sec. (blgw log) the hue bridge is nearly blocking. Only a disconnection between the blgw and the hue bridge help to control on hue side.
Any knowing issues with the blgw software and the new firmware of the hue system?
Blgw: v1.5.3.230 – Hue Firmware 1802201122
Thanks!
BeoLink Gateway | Release Notes
Changes in BLGW SW 1.5.4 since previous version 1.5.3:
New features
- Support for Home Control menu on BeoVision Eclipse. Configure this in the BeoVision Eclipse Settings > Sound & BeoLink > BeoLink > BeoLink Gateway.
- Support for forwarding Light & Control commands from BeoRemote One to BeoLink Gateway. Now using new protocol.
- Implemented GDPR compliance. Accept new Privacy policy and Terms and Conditions when each user logging into BLGW webpanel or setup page after firmware update.
- Home Control menu:
- Added support for P+/P- on thermostats.
New & updated drivers
- BeoLink driver:
- BNR source and channel selection commands do not attempt to re-select a source that is already selected.
- Corrected BNR channel selection command - Added a delay to favorites list that is executed only when the source effectively changes.
- Clipsal driver: added Shade, Shade toggle and Shade GPIO.
- Vantage driver: Solved an issue that would make the BeoLink Gateway disconnect from Vantage every 5 minutes
- 2N Helios: Fixed a bug that would crash the gateway if door was opened too long
- Lutron Homeworks QS - Radio Ra2 - Grafik QS driver:
- Corrected an error that made the driver fail when disconnected.
- Corrected an error that prevented the driver to go offline when the port is closed.
- Corrected and error that prevented the driver to catch events on certain conditions.
- Increased wait times on Lutron drivers, making them more stable.
Quality improvements
- Improved the firmware flashing procedure
- Camera URL syntax configuration improvements
- Several smaller bugs have been identified and fixed
Hi everyone,
first impression of the latest release is not good. Upgrade went through without issue but post upgrade no users but the admin one can access the web panel or use the iPhone app. So not exactly a well tested update. Does anyone else have the same problem.
Hi Again,
Managed to work out the issue with the web panel and it basically fails to load until the user has accepted the new T&C screen. Basically each user needs to visit the admin page of the gateway and logon and accept the T&C. After which the web panel and iPhone app start to work for that user.
I'm sure this is a feature but I'm not so sure because I would not want non-admin users having to access the admin setup pages in order to be able to use the iPhone app.
Steven
