New Beosound 3200 on the bench - no sound at all
Hi folks,
i just got my first BS3200 for my collection.
never had this one.
unfortunately it doesn’t work.
cd runs, radio runs, even the hdd powers up and I can control through the beo 4 and the panel directly.
Sounds good, doesn’t it?
but there is the proble - no sound at all, independent from the input source.
speakers power up, but no tone at all.
and: the headphones are also dead.
i pressed several times the mute button. Dontzknjw, if there should be a click.  There isn’t one.
it showed the change of the mute in the display.
But no change.
hopefully, there is something I could fix. Any idea?
best regards
69er
Update:
i ran testmodus 27.
there were several errors, but after clearing only one remained:
1 IIC 136 Sound Processor
which part is that? Is it the same as in an Ouvertüre? I have one, which could give parts
All the best
69er
Anybody here with knowledge about the CPU board?
I would like to keep this unit and not send it back.
Best regards
69er
Hallo,
das IC ist ein TDA 7318 SMD.
Kann aber auch das Eingangs IC2 defekt sein.
Oder die Mute Transistoren TR65 und TR68.
Oder die Spannungsversorgung +- 7,5 Volt fehlen.
Wird das IC4 warm bis heiß?
#(Korrektur) Das ist das IC auch für die Lautstärkeregelung.
Die Große Platine PCB 12 ist identisch mit der Overture.
VG
Hallo Comeobert,
vielen Dank für die Tipps - das hilft mir schon etwas weiter.
Das heißt, wen ich die PCB2 komplett tausche, dann ginge es?
Grüße
69er
Hallo,
da es identische Einheiten sind, ja.
VG
Hallo Comeonbert,
ich merke gerade, Du schreibst von mehreren boards, oder?
Das IC, welches Du beschreibst ist der Soundprocessor (1 IIC 136)?
Die TR65 und 68 sind auf dem preamp board (12).
Wo ist der IC2 untergebracht?
Viele Grüße
69er
I had a similar problem with my BS3000.  In my case, it turned out that the lithium backup battery had leaked onto the PCB and etched some traces under the battery.  I swapped out that PCB and replaced the battery and the unit now works fine.  Might be worth examining the battery and PCB to see if there's any evidence of leakage?
Bill
Guten Morgen,
die Bauteile sind alle auf der PCB12, nicht PCB2, sorry.
Das IC was ich meine ist IC4.
CD4052 sowie CD4094 könnten auch defekt sein.
Zuerst aber sollten alle Versorgungsspannungen kontrolliert werden!
Fehlt eine, dann kann auch eine einwandfreie Funktion nicht gewährleistet sein.
VG
Ich bin zu doof um die TR65 und TR68 zu finden. Tausch der Platine mit beosound Ouvertüre oder 2300 geht leider nicht. Sind unterschiedliche.
könnte mir jemand die bs 3200 reparieren?
bin überfordert
gruesse
69er
