Nest Cam
Nest is OK as a cam. Bit old now without any recent updates and the subscription service puts many off from buying, including myself. Works well enough though if you want to pay monthly for it. Other options are using your existing devices that have inbuilt cams (an iPhone and iPad for example) with a free app such as Surveillance by Reservoir Dev. Link
I have a Hubble - allows you to set for alerts, both movement and noise. Also cheap! We use it for monitoring the dogs!
A single wireless cam ? That's not a serious way to protect your house.
I have invested into mobotix cam inside and outside, a fierce dog, wired and wireless detector with the alarm system, real and dummy outside siren.
When they have the choice they will choose the less protected house.
That's sad what's happened in your area, but this is an issue also for any area in europa.
I would also change my avator for a moment 😬 That's scary !!
