Need help with my Beogram and Beocord, 1900 and 2400
These are the cables I have:
link
Filed under: , link, link link
link
Make sure your pics are smaller than 1000 Kbs
To upload pics to your files and keep them on the forum server, for later use, when making a longer thread, do like this
Click view all files, way down in the right corner
If you uploads pics without making folders, you will get all your pics in "my files". If you make folders, you can only make 9-10 folders, if more folders, you wont be able to open them when posting. And remember, write folder names like when you had a Comodore or PS1 computer, Nospaces in Folder name.
link
After adding a folder, you get this pane, open the newly added folder.
To add pics to folder, click browse, find the pic in your computer, click open or double click, then click add file.
After clicking Add File, your pane should look like this.
Now continue to Browse, select pic, Add File to this folder, or make one more folder and do the same there.
How to post the pics in your Thread or Answer, I will post in another page, its a Looong story, as we are working with bad or Outdated server software.
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
link
Filed under: , link, link, link link
Pics has to be less than 1000 Kbs
Start a new thread, or post an answer in a thread
Every time you insert a pick, you will have to run the whole click,click, and every time you insert a pic, the pane will reset to the starting point and you will have to scroll down to the last inserted pic.
It easier to just write the text, insert pic from options, post, answer to thread and insert one more pic and so on.
This way is a waste of time.
Retired
Rock and Roll music
Collecting Vinyl
Its easier to upload your pics to a server like Photo bucket, find your pic, copy the direct link, click the film strip paste the link and insert it, done, just keep your pics under 1000 pixels
Retired
Rock and Roll music
Collecting Vinyl
I got your pics in my mail, a lot of cables and converters, as Martin says the BG 2400 normally it has a 5 pin din plug, if it has RCA  connectors you will need a RCA to 5 pin din male converter, connect that one to the Phono input.
For the BC, you will need a cable with 2 x  5 pin din male, in your pics you showed me a cable with 5 pin din male to female, and a converter 5 pin din male to RCA, probably the BC has been connected to an amp with RCA jacks.
If you post pics again show both ends of the cables or converters, and for the BG tell us it is the BG, converters is where you have a 5 pin din to RCA or visa versa.
5 pin din male has pins
5 pin din female has holes
Retired
Rock and Roll music
Collecting Vinyl
Dillen wrote:
The Beogram cable is permanently fitted to the Beogram.
I wonder if the US model might have a different set up? Maybe like the BG8000?
I have and have had several US BG models and there is no standard about the plugs, some comes with the DIN connector and some with RCA.
Retired
Rock and Roll music
Collecting Vinyl
Got your last pic.
Upper right must be for the BG 2400, so connect the the 5 pin DIN to the BM 1900 phono jack, and the RCA end to the Beogram cable, the single wire to the single wire coming from the BG 2400.
upper left is for connecting to the female end of the male/female 5 pin DIN cable, the male end goes into the BC amplifier jack.
Lower cable in the pic is a converter cable for incoming and outcoming signal to tape input on the BM 1900, connect the 5 pin DIN to the tape jack, now connect one of the pairs to the in the pic upper left RCA connectors (connected to the Male/female cable), play a tape and if sound is there its OK if not change to the other pair and try again
With the existing cables this is the only way to get it working, best is to get a male/male 5 pin DIN cable that goes direct from the BC to the BM, you can get one from Steve at Sounds Heavenly at the bottom of this page or search on Ebay
Now, this will only work if your components are working properly, they are old and if not serviced they will need service and/or repair
Retired
Rock and Roll music
Collecting Vinyl
