i recently purchased a Bromaster 1900 which came with a Beocord 1900. I also have a Beogram 2400 which I would like to set up as the turntable with the other 2 components. I am very new to purchasing audio equipment, so I apologize if my questions are so amateur. I would just like to know if the 2400 is compatible with the Beomaster 1900 and if so, which connectors/wires I will need. The Beomaster 1900 did come with some wires but as I am new with this, im not sure how to connect them to the Beocord or the Beogram. Any help will be greaty appreciated. I am very excited to be a part of this community.
Need help with my Beogram and Beocord, 1900 and 2400
Welcome to the forum, The BG and the BC should have 5 pin DIN plugs that fits into the Phono and tape jacks on the BM 1900, some pics from the cable plugs will help us help you. The BG 2400 is compatible with the BM 1900
Printing machine technician
Rock and Roll music
Collecting Vinyl
Thank you, I will post some pictures tonight when I get home.
Also, while we are on the subject, I have a CDX. I doubt this is compatible with the 1900, but I did read that it may possibly be able to be connected via the phono system through the Beomaster.
The CDX works fine with the 1900 but you will need a phono to 5 pin adapter and use the tape connection. There is actually a specific connector which has a switched adapter which allows a tape and cdx to be connected.
Ok, here are some pics of the connectors that came with the Beomaster:
This is the connector I was remembering - I did have one though I have probably given it away. Worth looking for one.
Thank you for the info! I will have to look into this. I just realized that the photos I posted didn't show up here on the site for some reason. When I purchased my Beomaster, it came with plugs, but what confuses me is that the Beomaster and Becord both have "female" ends for connecting, so I"m not sure how I'm supposed to connect the 2 components. Also, the Beogram 2400 came with a gray wire that doesn't match the other one. I'm still pretty lost...
You should have a 5pin to 5 pin DIN cable - that connects the Beocord to the Beomaster. The Beogram uses a slightly different cable because it has an earth cable included connecting the plug shields.
The Beogram cable is permanently fitted to the Beogram.
