Hello all
i need to find a beolink compatible dimmer for my kitchen lighting.
the lighting is now installed but I have access to the positive and negative at the switch.
the kitchen lighting is split into two feeds one for the dining room and another for the kitchen side, they are also LED lights. I need a control box I can install or a dual switch that will be BLGW compatible.
any thought so I can add my kitchen to my new gateway when it arrives.
ideally I would love a lutron switch that had some words on it like the below and also plain up and down buttons.
Cooking
dining
Party
Would it be a good idea to buy a grafic eye from eBay are they LED compatible also?
