Hello,
I've recently purchased a MCP 5500 for my Beomaster 5500. It worked well for a while initially but then quickly showed various signs of malfunction like show No contact or wrong indication whenever I push a button. Replacing the batteries couldn't help.
Now the MCP stays in a steady state where it doesn't contact with my BM5500 at all (I checked with another Beolink1000 to make sure the BM5500 is working normally). It (the MCP) keeps showing "Standby" and "Set clock" and won't turn off unless I remove the power, pressing whatever button does nothing.
Following are several attempts I've tried (mostly following the hints in BM6500 service manual):
- Replace batteries with 6VDC from my bench supply, the consumption is approx. 80mA steady.
- 4.75V line: I've checked and readjusted R117 to make sure it's 4.75V
- 12TP3: Since the MCP stays on, I thought it has smth to do with TP3. Its voltage is measured 30mV, checking pin B of TR41 (which serves to active TP3) is 0.56V. It seems TR41 has no problem but likely the CPU keeps sending "Supply constant on" signal.
- 12TP4: the display did flash when I checked this test point (shorted to neg. supply). Power consumption jumped between 60 and 80mA (probably due to the display flashing). The MCP stayed on that state (flashing) whatever I do unless remove the power.
- 12TP1: the MCP did transmit a 200uS/3.1mS pulse/pause signal (measured across D3 of PCB 13/14 with my oscilloscope) following the test BUT did not stop when I push a (whatever) button.
- 12TP2: I didn't check since the display kept stay on anyway.
- Volume wheel: removing the connectors from Volume wheel (in case there's something wrong there) didn't help at all.
Now I'm stuck and clueless. Any suggestion is welcomed.
Thanks,
Duong
