MCL2AV Type 2026 - SW2.3 - polarity of the DC power input
Dear Forum,
since my newly added MCL2AV has got no power adapter, I just bought one from Amazon.
Now the question is: what polarity do I need to use?
I will try to use the MCL2AV with transceiver to use a second Beosystem in my Office (Link Mode).
Thanks for your help!
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096 Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55 Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL) Bedroom: Sony KD-65XH9077, Beosound Essence MK II with Beolab 6002 and Beolab 11 (all white, wall-mounted) Dart Room: BeoPlay V1-40 on floor stand Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Hello Ralf,
for the power connection you need the polarity scheme on the right side. The positive 15 V has to be on the outer connection and ground has to be on the middle hole of the power cable.
The MCL2AV power connection has the ground at the center pin and the +15V have to be supplied via the shield connector.
