I got a pair of mc 120.2 speakers and one woofer is dead. Where i can find one?
MC120.2 woofer, where to find a replace?
Where are you located ?
Sorry😁 I’m in Finland.
When you say the woofer is dead -what do you mean?
Perished foam surrounds ?, total burnout of voice coil ?
Noel.
Hi! Foam is replaced, but voice coil is burned. So completely mute/ dead😭
So sorry to hear that, and it's going to be tough to fix the problem .
I've done an extensive search on Google ,through the web-sites I know about ,and the the only thing I could find was a foam surround for the woofer-(no re-cone kits though.).
Sorry I couldn't be much help,
Noel.
Yes it’s a tricky one. Thanks to you anyway! Second hand woofer is only solution, must continue the hunt.
No worries.
Noel.
Have you got a speaker repair business in Finland ,that you could send the woofer to?To be re-coned?
Noel.
If you plan to make a trip to Tukholma by cruise. Send me a message. I do have a pair of MC120.2 s that i´m not using. Send a message.
