Evening All
Just been inspecting the foam surrounds on my MC120.2s as I know they need refoaming due to foam rot. I was playing a track and noticed that one of the woofers is dead. Had a quick look inside and no obvious spade connectors have come loose. Is this a problem with the crossover, and if so, can I do some fault finding with a multimeter??
Thanks in advance.
John
