I've had a battery leak (dratted Duracell) into my beautiful MCP 5500 and it has damaged the corner of the PCB which has six resistors: two each of 0.82, 330 and 1500 ohm. The damage is very localized, but it has damaged the tracks, too.
I can remove the old resistors, rub down that part of the board with wet & dry paper, neutralize the nasty chemical and solder new resistors into place. However, I also need to replace the tracks which have been destroyed.
I've looked on the Main Site, but could not find a service manual.
Does anyone have a copy of the schematic, or a diagram which shows where the tracks should run, or a photograph of that corner of the board (both sides) that they could let me have?
Thank you in advance,
Mark
