Hi all,
After many many many years my M100 speakers need some work. Most speakers are okay, the woofer has no dried out rubber, and it's coil moves fine, and just has a dent in the paper dome. Alas, the one above it is gone. I opened up the case of the M100, but this speaker is in the sealed compartiment, and everything is glued, even the wires are glued tight.
I removed the speaker from the front and unsoldered it, hoping to find a brand and type, so I can replace it. But, there is not much. Just 8Ω and 770518, no brand, no type. Anyone an idea what it is? pic:
Would repairing the speaker itself work well? I see some workshops do that.
Thanks!
rick
PS The 3rd speaker from above had a bit of a dent in it's rubber dome. I tried to un-dent it with a bit of tape, but it does not stay un-dented.
PPS The tweeter has lost it's metal dome, but I don't think that matters much soundwise.
