Is anyone familiar with one of these? I understand they are sold in Denmark only.
I am wanting to use this to control lights with Beotime? Is it possible?
Thanks.
Thanks.
I have a couple of those. I have no experience with the Beotime, but the 350 is operated with one of the 4 coloured buttons. You turn them on by pressing LIGHT then red, green, yellow or blue. If you want to dim the lights, you keep the button pressed. As I remember you cannot use the numbered buttons.
I'm very happy with mine as they fit in the wall socket, but you have to point the Beo4/5 directly at the unit as it's receiver is no where near as strong as on the LC2 or other B&O equipment.
Thank you for your reply. They do seem pretty good but if the signal is not very strong then I might be better off getting something else. In Denmark, what other B&O light dimmers are sold?
Thanks.
I have bought this one in Denmark, it's great: Here's the link for the UK site:
