LC2 blocqued on
Hi Everyone
Just received an LC2, after opening the neutral and ground stripes on pcb were burned.
After have them replaced by thin wires and pluged in outlet the LC2 shows power 238 volts.
But I was not able to turn it off, not by touching or with the BEO4 pressing light and stop.
If someone has a service manual of this device or already had this problem.
regards
patrick
can you take a picture (top/bottom) of the board?
several things can cause such problem like the zero crossing detector / dead microcontroller / dead triac.
