LC2 - not functional by touch control.
Hi.
I have a LC2 and a Beo4 to operate it remotely. The problem is that i can not turn on/off on by touch control on the LC2 it self.
I have read the manual and know it's a configure sequence to be done on the BEO4 to able the touch function. But it won't work.
Maybe i do wrong when programming it with the BEO4.
Both the LC2 and BEO4 are bought secondhand.
Anyone that have suggestion for me, please.
Brgds Daniel
Hi, !
You can fix it, by filling out the silver line. On the inside of the black plastic. !
Mvh
Hi Talisman
Thanks for your answer and help.
But I'm sorry, i don't understand your answer. Would you please specify with what you mean with filling out the silver line?
Maybe i need to mount it down see what you mean?
Actually it would be great if you could explain for me as if i would have my fifth birth day soon.
I have no problem putting my hands in to stuff if i get a childish instruction :-)
Looking forward to you reply
mvh
Hello,
You have to unscrew the black touch half of the LC2, inside it is painted a thin silver line. It shall be fill in with silver paint (the one you use when you repair electric rear window of a car)
Mvh
I agree with Talisman. Must be the black dome. I recently had the same fault with one of my LC2s. Just ordered a new black dome and replaced it.
They are still available and not so expensive as far as I remember...
med venlig hilsen ..:)
Stefan
Hi where did you order a new black dome from?
Hallo. I still have one or two spares if you were interested. Greetings, Kai
