Is anyones BROne "Crunchy" ?
i have noticed that my BR One is crunchy when you press the keys
when you take it out, its normal. its just how it sits in the housing.
Anyone else have this issue?
Michael.
I have the same.
I tried to stuff some cardboard between the battery housing and the aluminium body, since I think the sound is originates from there. You are correct that when the keyboard part is slided out, there is no noice.
I have not totally manage to remove the chruncy feel / noice.
Have they acted like this, from day 1?
No, it came over time.
Correct. It came over time.
It’s not the module as if you take it out of the casing it’s fine. It’s how they connect together.
