Aad Jansse wrote:
I got a pair of hearing aid devices the other day, which gives me access to the higher frequencies in surrounding sounds. It is only too bad that these things also amplifies the nasty sound that the BM1200's transformer produces. It was not a disturbing thing before.
Apart from taking away these devices from my ears (I appreciate the improved sound reproduction through the speakers very much) what could be done to eliminate this humming?.
I'm slightly confused by your description of the problem.
You're talking about the improved high frequency range that these hearing aids offer, suggesting that this "hum" is in the higher frequencies. On the other hand a classic mains hum in Europe should be at 100Hz, i.e. that's at the other end of the spectrum common hearing aids can "hear". (When my mom got hers I looked into technical details and it seems that even the top of the crop devices only have a frequency range of 80-8000Hz.)
To come to the point, I guess my question is: is it a physical noise coming from the transformer or is it induced noise that is coming from the speakers - and then of course, is it high or low frequency?
I'm interested in your post and progress because I have a similar problem on my BM1000. I haven't gotten around to pin it down yet but in my case it is a physical noise coming from the power supply or transformer and it only starts approx. 30seconds after switching on. I think it has to do with the current drawn from the transformer because when I disconnect the speakers the hum doesn't appear, well at least not so annoyingly prominent.
In my case I'm guessing it has to do with leaky old capacitors that put some strain on the power supply, but I haven't gotten around to recapping...let's hope that corona is around for a while longer, so that I can find the time... ![Erm..]()
