Hue Adrress?
I just added 2 lights in a bedroom form Hue. Imported the scene. First Setup was done by a technician, I am simply adding lights.
Setup was Garage - Hue light x- Light dimmer - 1 (Address from 1-9)
Now adding
Childsroom - Hue light x+1-Light dimmer - 10
I did import the resource and the address it gives is 'streaming' so just changed it to the next number 10
What am I doing wrong? It simply does not work.
Thanks Chucky
This is really not OK, had to log in and push commands like debug etc... it should be simple.
Got it working though.
chucky wrote:
Now adding
Thanks Chucky
From Beovision to doorbel...all B&O what rings.
I’ve noticed this as well. Had to manually input an ID for each dimmer or they wouldn’t respond.
Check these out CHRIS, hue switch from Gira, wireless and the work great.
https://www.gira.com/nl_NL/gebaeudetechnik/produkte/manuelle_lichtsteuerung/zigbee-lightlink/features.html
Batteries 2 years, a pain to program with the btidge but when they work.😐
I use them with the BLGW. I am now looking to sen ir commands through the BV and beo 4 switching them with a light control but I am not technical
Ooooh they look cool!
I use them with the BLGW. I am now looking to sen ir commands through the BV and beo 4 switching them with a light control but I am not technical From Beovision to doorbel...all B&O what rings.
Hey Chucky, can you pickup these commands on the BLGW directly from the switch?
No, the switches work stand alone, they do not have an ir or are visable in the Hue bridge. I think you can even prgram them without the hue bridge, I did put them in the bridge but when I launch an Api I do no see them.
Workaround could be to set the lights, program in the switch amd then save the scenario on the hue bridge. I did program my beo 4”s in every room and have full control and an ipad with the beolink 2 app.
Still in the in hunt to get my lutron in the living and kitchen going, bought an rs232 interface on eBay yesterday.🤩 got it cheap so let”s hope it works.
Hey 'chucky' what Lutron platform are you using?
Grx|-3104
I just bought this on ebay
Lutron Grafik eye rs232 interface
Grx-CI-RS232
How do you setup the switches with the hue bulbs then?
Cheers
Chris
