Hello there
I have started my first renovation project. A BeoMaster 3500 from 1998. It fits perfectly on the shelf where it should be (and it fits the Misses:-)). Until now, power cord is changed since the previous owner had shortened it to 10 cm. Then I changed the speaker relay, as it only plays in one channel. If you pressed the "Mute" button several times you could sometimes get it to play in both channels. To be sure, I changed the relay, as it is still available as spare part.
Now for my question: The radio suffers from BM3500/4500 syndrome. The glass plate with touch panels is loose, (but whole). I want the old glue removed so I can glue it togehther with something new. I've tried with a knife, with the result that I had to repair the glass with nail polish. Are there some "chemical stuff" that can remove the old glue from the glass plate and the brackets?
