So the BL convertor has a female Masterlink connection, and it takes a male-male ML cable to connect it to the BM5?
How can the BM5 be switched to this aux audio input?
Yes that is correct. Simply press any video source button (eg. DTV) on the Beo4 remote to activate the converter and play the TV audio.
Kind regards, Steve.
Hello Steve.
I have no analog output on my Samsung tv. How is the best way to connect it to my Beosound 5?
Best regards
Søren.
Hi Soren,
In this case, you will need an optical to audio converter, plus the Beolink Converter mentioned in the thread above. Please ask if you need any help with cables to connect these.
