I have a Samsung Smart TV with the following Audio Output options: HDMI ARC, Optical, Bluetooth. There are no analogue audio out ports. I wish to feed audio from the TV to my BeoMaster 5 which is physically adjacent to it. I don’t want to feed directly to the speakers or BeoSound 5 to avoid visible cables.
Additional information: The TV is fed from a Virgin TiVo box via an HDMI cable. The TiVo box, the BeoMaster 5 and the Smart TV are all on my home network. Is there a way of feeding the audio over the network?
The only other option I have been able to find so far is to use a Behringer UCA222 to plug into the USB Aux In port on the BeoMaster 5 but the UCA222 only takes analogue audio inputs. Converting a digital signal from the TV to analogue and back to digital for the BeoMaster 5 seems messy, expensive and could produce latency issues.
Does anyone have any suggestions?
