I have the BLGW connected (among others) to KNX. The integration works well from BLGW to KNX (e.g. when I press the Lutron button it starts the BLGW macro that is transferred to KNX and it works). I also have the KNX thermostat and CO2 sensor, that I am able to read from BeoLink (so, BLGW can read the specific existing Group address - if the macro is initiated at BLGW).
What I want to do is that pressing the button on KNX wall panel will switch on the BeoLab (It means that the macro is initiated by KNX). So, I have put BLGW into "capture" mode at Resources page, but cannot get any signal.. The KNX telegrams just cannot be seen in BLGW admin interface.
I have also created the Group Address at ETS and tried to use it as the trigger in Macro. The addresses has the CR-T attributes as described in Help, and I tried both with Virtual Tunnelling and without. No any success.
Does anyone know where to look further?
