How many different stand types vor Beovox speakers were produced by B&O?
Would the stands for Beovox S45/S45-2 fit the Beovox S-80?
I found few older threads with the similar issues but not the answer to this.
Actually it would be nice to know how many types of those stands for Beovox Uniphase ware available in the 70/80's?
I found the post by Martin about type 6013 and 6017 (supposed both fit Beovox S45/S45-2, different only in height). There must be a bigger version for M(S)100/150 too. Type number?
And of course there are 2 trumpet stand types.
Anybody knowing other stands? Type numbers? Pictures?
Nobody knows if the stands for Beovox S45/S45-2 would fit the Beovox S-80?
Beovox S80 stands will mount to the fittings at the back of Beovox S45.2 but the height would be wrong.
Stand 6012 is for Beovox S75
Stand 6013 is only for Beovox S45.2 type 6312. (There were no square stands for Beovox S45 type 6302 - and no holes provide for it at the back).
Stand 6017 is for Beovox S55 / 80 / 80.2 / 120 (and I seem to remember also S45 (type 6427).
The M75 and M100 uses black stands with bigger footprint (Type 6010 if I remember correctly).
Beovox M150 uses larger and higher stands
Beovox MS150 again larger and higher.
- The above are from memory - there are more...
Hi Martin,
thanks a lot for answering my first question.
So I tried to consolidate your information about the stand types in this table:
Normal 0 21 false false false DE-AT X-NONE X-NONE
Stand types vor Beovox Uniphase speakers
Stand (type)
Color
Speakers
Note
6012
silver
Beovox S75
6013
silver
Beovox S45.2 (type 6312)
6017
silver
Beovox S55 / 80 / 80.2 / 120 (also S45, type 6427)?
6010?
black
Beovox M75 and M100
Beovox M150
Beovox MS150
I hope we can find the missing types in future to complete and extend this table. It could be interesting (at least for me) to have it as a reference.
Thanks again.
M75 - stand 6011 - included as standard
M100 - stand 6010 - included as standard
M150 - stand 8960160
MS150 - stand 8960150
The 6017 stand also fits the S50s
Cleve
Thanks Peter and Cleve,
here the updated spreadsheet:
Stand (type)
Color
Speakers
Note
6012
silver
Beovox S75
6013
silver
6017
silver
Beovox S50 / S55 / 80 / 80.2 / 120 (also S45, type 6427)?
6011
black
Beovox M75
6010
black
Beovox M100
8960160
black
Beovox M150
8960150
silver
Beovox MS150
8906007
silver
Beovox 3800, other?
Trumpet stands
Beovox M70 / S75
Trumpet stands
If anybody knows the type number of second type of trumpet stands or have other stand types, please write it here. I will update the table.
Thanks again to all.
I also think the 6013 stand will fit the later model of the S30 (model 6317), but someone might need to confirm that. The dimensions of the speaker and photographs I have seen of the back would certainly suggest the 6013 stand to be the correct fit for them.
Cleve
Was the S75 available with the option of both square and trumpet stands?
Ben
The optional stand for the S75 was wall mounting kit type 6014 - I do not recall any of these speakers having trumpet stands
