How do I pair my Beoremote one bt with my Beosound 2?
Seriously....wasn’t your dealer able to explain this?
Look here:
Look here: link
Thank you for this information My dealer aside, it’s not like pairing is very intuitive. Although pairing is explained in the BEOREMOTE manual, I could not find any information on how to pair the Beosound 2 (it’s not like this is very helpful
The ‘controlling with a BeoRemote One/BT’ was a feature, that was added later and - sadly - that guide on the website does not mention this/was not updated.
Basicly it works the same for all newer B&O products - (as shown in the video) prepare the device for pairing, open the pairing mode in the remote control........I did not find that hard to do.
(After being paired) the remote takes over the informations coming from the device - in your case the BS2.
These informations are in the BS2 because you have ‘told’ it to add a certain TuneIn playlist (= your TuneIn favourites).
These favourites are managed in the TuneIn app, where you make an account and login - that is where you go, if you want to rearrange the stations etc.
The BS2 merely takes over these settings, when you - in the Bang & Olufsen app - enter your TuneIn account along with all the other preferences/settings that you can mak there.
In short....make a TuneIn account then make a favourite list of the radio stations there, after that enter your account for the BS2 in the Bang & Olufsen app - and the list of stations should show up in the BROne/BT, when used with your BSOne.
Correct.  The stations in the TuneIn list are those of your favourites on your TuneIn account.  I haven't found a way of "navigating" to all TuneIn radio stations in this use case.
I just default to the BeoApp now instead.
