home control basic - MLGW
Home control without a expensive light/home control system:
This is my configuration at home and it is working for many weeks without faults.
Masterlink:
In every linkroom mast be a b&o device connected to the masterlink. You can find here a list. link
With listed software version (or newer), product can pass LIGHT and CONTROL commands from remote to MLGW. If your device is not able to do this or there is no software update than buy a second hand beolink active an a new software chip (min. sw 1.6) install this in your linkroom and program it to L-option 0.
MLGW or BLGW / Lintronic TT455-RT-238
Are linked via rs232. The MLGW send via customs Strings (<0100232132001--->) to the TT455-RT-238. The TT455-RT-238 converted this string to a ir command “key1” and send this to the light manager air. The ir send and receive-units a very strong, fast and without faults! (the TT455-RT-238 can also converted ir codes from the beo4 to a non b&o device. Take a look on the homepage from lintronic.
JB Media Light Manager AIR
A new very clever device! Take a look: link
Is connected to the wifi and has external antennae. Very strong sending of 433 and 868MHz rf codes. A very smart software to build very easy complex light scenes. You can also program light scenes to depend on temperature, time or the position of the sun.
So you can program “key1” = switch on 50% lamp1 and 30% lamp2 and 0% lamp3; switch on the espresso machine and close the shades only if there is sun outside… and al this only with one command!
maybe you can control the light manager direct via custom strings from the mlgw. But unfortunately, all previous attempt brought no success. (contact me if you have a solution ;-)
Intertechno/CoCo/FS20:
One of the cheapest dimmer/switch, etc. (20 to 40 euro)
Led, 12v, shades, dimmer, 0-10v led, …..etc.
Control:
You can now control from every room the light, shades…. Your b&o of course with your beo4, beo5, remote one, iphone app beolink and with the beosound essence remote. Or buy a wall charging-station for the iphone or ipad and you have a touch monitor on the wall.
beoandy
