Hi there,
I'm only new here after purchasing a Beogram 1001 on ebay.🙂 I also purchased a cheap din socket/RCA adaptor to connect to my amp (Arcam Alpha 8 with phono stage). Now, the problem I'm having is I'm getting a very load humming sound, that only disappears when I move around the din socket lead that's connected to my amp. It can play away beautifully at times with no humming sound at all, but the slightest movement can cause the noise to return. The turntable also didn't come with an earthing lead i.e. a lead that connects my amp to the turntable. Should I be using one of these? And/or is my cheap din socket not really suitable (only €3)? Any help is greatly appreciated. Thanks a lot.
