i have just received a Beomaster 1000 from a friend but there are no speaker plugs to connect to the amplifier.
As I am not great technically I'm not sure if I should use the 2-pin DIN plugs I have found on eBay or if some other type of plug is required. Also is it 2 plugs per speaker or one?
Any help is greatly appreciated!
regards,
Graham.
