Help! Speaker plugs for Beomaster 1000
i have just received a Beomaster 1000 from a friend but there are no speaker plugs to connect to the amplifier.
As I am not great technically I'm not sure if I should use the 2-pin DIN plugs I have found on eBay or if some other type of plug is required. Also is it 2 plugs per speaker or one?
Any help is greatly appreciated!
regards,
Graham.
Hi Graham!
Yes these are the ones! 🙂
I do not know where you live (in the UK I reckon 😕 ) but here in France they are still widely available at DIY outlets and component retailers', and they are very cheap.
One DIN per speaker it is. The small peg is the + and the flat one is the -.
Welcome to Beoworld!
Jacques is correct!
you can pick them up from most DIY shops in the UK as well!
Ben
These will do the job for you:
http://www.ebay.co.uk/itm/2-X-2-PIN-SPEAKER-DIN-PLUGS-MALE-HI-FI-CONNECTORS-EASY-FIT-SCREW-TERMINALS-/190882903916
http://www.amazon.co.uk/Pack-Speaker-Loudspeaker-electrosmart-Connections/dp/B00512QE4I
If you do not want to solder then the screw terminals would work....
Enjoy the music !
Brian
Enjoy the music !
Brian
Thanks Brian!
Thanks Jacques!
You are most welcome Graham.
Double post again. 😭
