HELP: How to remove 'Teletext' and other items from the LIST menu
Hi everyone,
I just got a new Eclipse to replace my BV10 and I can't get the LIST menu as clean as I would like to. I don't have anything to use with LIGHT or CONTROL and I don't have a TV antenna connected so no use for TELETEXT either.
Is it possible to remove this items or at least move them to the lower part of the menu? I had a BeoRemote to control my BV10 on IR and I could add or remove anything I wanted from the LIST menu.
Btw, the new BR I got with the Eclipse is the one with the Netflix/Amazon (ugly) buttons.
Thanks!
I am in the same situation but don’t think you can completely customize the menu. Sadly. If someone knows differently I would be eager to know
I know this is an old thread, but there is a way to remove the LIGHT and CONTROL menus from BR1. You have to first switch to an IR product (e.g. BeoVision) and the go under Settings. Here you can configure what you show under the LIGHT and CONTROL menus. If you remove everything, the menu options will disappear from the LIST menu. But the trick is to select an IR product (even if you don't have one) - otherwise you won't be able to edit this under settings.
If you want to see it explained have a look here:
