Help getting beomaster open
Ok, I feel really stupid asking as question like this, but how do you get the cover of the tone control section from a beomaster 2200 off?
I cannot find any screws or clicky things. I tried by removing the complete bottom but that the board under there is screwed to the bottom and soldererd to the RF section that will not come out that way. I think I can see that the volume control board being screwed down from the top, but how the get the cover off?
Hi Martin,
I spend an hour wiggling that cover before I wrote this post. But at your suggestion I tried again and nothing. I then inserted a screwdriver just above where the black wire comes in and it finally popped off. So yes wiggling works🙂, but it does have two hooks at the bottom that hold it down.You can see them in the picture. Next time I will use a screwdriver on those, lest I break something.
Thanks for you quick reply and confirming I was not missing any screws!
Nice how all that dust shows when using the camera flash...
