I'm replacing all 4 of the 63v capacitors on the crossovers during my rebuild of the Redline 60 model #6503 to the Solen 400v metallized polypropylene ones..
I have all of the values of the 4 capacitors, but the green resistor is only labeled 39R 5%. Can anyone tell me what the value of this resistor is, or do you have a schematic you could send me?
I'm also curious about the ratings of the three inductors on the board, two air core and one steel wound. Any idea what the mh rating and gauge of the wire of these are? There is also another inductor, plastic wound mounted to the chasis that services the lower driver.
Any information would be appreciated.
I'm making a permanent modification of the foam ABR's which have failed too, so I should have a first class pair of 60's when I'm done.
Thanks,
Mike
